core what a night
mtb
30 Jan 2002
Been down tug to do bits and dicided it would be perfect for a late night run out in the wash !!.
Earlier today saw what I thought was a Black Kite soaring and gliding above the field , bit rare if it was .
Tide quite low but I thought mmmmmmmm ye of little faith so started engine let go cables off we went .
Lovely feeling , you know what its like the urge to travel the freedome ,
but after 100 yards poxy bottom huh!
So I had to push it around back over the sand bank and back on to the moorings , quite wierd actualy on the bottom but able to push it through .
Oh and got a sniff of a BIG tug as yet got to sort pennys but ooohhhhh.
Mick
http://homepage.ntlworld.com/boats
I want a big steel ex trawler / tug v / cheap or swap for tug
mtb
30 Jan 2002
Hello mate how you doing !!
re the thingy no ta got one a few weeks ago ( given of course )
Oh just incase out side sitting on the drive is a heat exchanger a big one up to 100 hp . Stand alone type Serk on the casing 20"" long and 9"" wide, one snag the casing has split due to frost damage but could be repaired
( tig or gas ) postage blimey quite heavy as you'd expect .
So if you cant get any thing to do the job this would once welded do the job.
Cheers
Mick
mtb
30 Jan 2002
Re: thats true
The prop on the tug has nice clean blades just like sand blasted and after a couple of years it would wear the ends quite thin.
Has the fishing got started yet up at wells !!
Mick
