BabaYaga
I mentioned in a thread in January my plans for having the blades of the feathering propeller copper plated and to skip the prop zinc anode. The main purpose being to reduce/eliminate the growth of barnacles on the blades:
Bronze prop with no anodes – what will happen?
I lifted out the other day, so thought I should report back.
From the fouling point of view the result must be described as successful. Not a single barnacle on the blades and just a few on the stainless steel hardware on the propeller hub and the protruding shaft end. The hub was not plated, but primed and spray coated with Trilux. The stainless parts though were not properly primed, only spray coated with Trilux just before lift-in, a coat that apparently has not stayed on.
For comparison, this is what the prop normally looks like at lift out in October, after 6 months in the water, starting out well polished and with zinc anode attached:
(And this sorry state despite me having snorkeled down mid season to clear them off...)
One result less successful is that some of the copper plating has peeled off near the leading edge on one of the blades. Perhaps due to inadequate preparation at the electro platers...?
