MM5AHO
Someone mentioned dezincification recently to me, but that got me thinking about copper fittings in seawater service.
Any thoughts about copper pipes in seawater?
would be interested to see whether we should use it or not
I have a 15mm copper pipe exposed to sea water in the bilge (I use it to drain the exhaust antisyphon box before leave boat - long story), I put it there 3 years ago expecting it to crumble, it seems fine?
In isolation there is no galvanic action, but if the copper is in any way connected to other metals in sea water it's likely to dissolve, check the EMF series to see where it sits it is certainly more reactive than an SS it may be in contact with.Someone mentioned dezincification recently to me, but that got me thinking about copper fittings in seawater service.
Many wooden boats were copper fastened, and have lasted for years.
Unless of vast antiquity I think you'll find they were bronze fastenings.
Copper does gradually corrode in seawater, hence the use for anti-fouling on square-riggers.
Steve may find his windsurfer mast section will be even more short-lived than the copper one - all depends on the galvanic couples present.
It's common brass that de-zincifies and turns into rather porous and weak copper.
I think you will find that the vast majority of clinker boats were fastened with copper rivets.
I changed most of the seacocks. Used DZR ballvalve (though I think the ball is 316 SS??).
Almost certainly chromed brass.
