Clyde_Wanderer
While motering into Rothsay this wk end, my cooling water intake got blocked but was noticed almost imediatly, but had to complete journey with aux o,b as it was too dark to sort problem, which I sorted next morning by connecting dingy foot pump to intake pipe and pumping until a huge burble was heard, and hey presto clear.
Infact this happened twice over the wk end, which got me thinking about some sort of quick, get me out of this situation cure, now what I came up with is, a twin skin fitting, perhaps 1-2 ft apart each with its own ball valve, both running through a Y branch to the single pipe, then to filter.
While motoring only one valve would be opened, so if it gets blocked you close it, then open the other and continue on your journey until such times as you can clear the blockage, as the chances of the two getting bloched within a reasonable time of each other is slim as you wont have any vacuam on the closed valve.
Any opinions?
Any opinions?
