Coolant temperature sensor on Merry Fisher 805 bust.
chuzzlewit
26 Jun 2006
Poole
It's a Nanni 4390 tdi (marinised Toyota engine 200hp). I've snapped off one of the two electric tabs (lugs?). I've unscrewed it and there's a 1cm diameter brass rod which projects about 3cms into the coolant.
Any idea where I can get a replacement and what I should ask for?
asap supply's have all sorts of sensors
picture and specs are shown online,
perhaps you can find a replacement there ?
The nanni engine is only a Toyato 1kz which is base engine for Toyato so i would try any dealer i.e http://www.roughtrax4x4.com/?doc=16&cid=1030&vid=1368 . I use these guys for my service parts for my nanni 3.90tdi . They should be able to help as the nanni engine is only base engine but put in to marine use. The running temp should be the same. May be worth a try as any nanni dealer will be expensive
