SimonA
I've an ancient BMC Diesel engine which was totally rebuilt five years ago. It starts fine (no compression problems) but is showing what I think might be head gasket or warped head symptoms. The coolant level drops by about two litres after an hour of running but the engine does not overheat. If I top it back up and run with the coolant cap off the Bowman heat exchanger the coolant quickly overflows and has bubbles in it. I've also got a diesel leak under the head gasket joint on one cylinder, this is the part that confuses me the most as I've no idea how diesel could leak from the head gasket. Is it possible for a warped head to cause a diesel leak?
