emandvee44
I need to change the coolant.
Volume of the system is 9.5 litrês.
The manual says if risk of freezing, 50% Volvo Penta Anti-freeze (Glycol), 50% water.
The manual also says that if there is no risk of freezing then use only water and add anti-corrosion agent.
I assume therefore that the Glycol acts as an anti-corrosion agent?
Will any engine coolant be ok?
I have found 2 litres of engine oil on board, which I plan to put in the saildrive. Slightly different spec.(see pic.) Can I mix them?
Thanks,
Michael.
Thanks,
Michael.
