Converting Lavac to electric
Kelpie
15 May 2005
Afloat
After two years of living aboard full time, we are starting to think that it's not complete decadence to upgrade to an electric heads. And ensuring that the heads gets a proper flushing every single time might extend the interval between servicing (a fancy term for bashing all the limescale off the pipes).
I know you can buy the Lavac pump but at ~£260 it's not cheap
AFAIK all I need is a 1 1/2" diaphragm pump, and it can sit in line with the manual one.
So would this one do instead?
Whale Gulper Grouper Mk 3 Fishbox Pump with 90° head
I converted my lavac head to electric with an electric diaphragm pump
Cannot remember which one but any 1 1/2" will do
I also fitted a time delay off switch set to ensure a long enough flush simply by pressing the button and walk away.
I did the same as Roger, i used a Jabsco waste pump, worked great.
I would avoid the 90 degree pump in post #1
