Converting a Prop
Stemar
12 Sep 2001
I need a new prop - 15 inch by about 9 pitch. My shaft is 25mm with a standard (1in 10?) taper. I would MUCH rather get a second hand one, but the only ones that seem to be around at the moment are for 1" shafts with a 1 in 12 taper.
Does anyone know a company either in the London or Gosport areas who could bore out the hole to match my shaft?
Thanks in advance
dickh
8 Feb 2002
Suffolk
Any engineering company could do it for you - but you may have a problem boring out an Imperial taper to the metric one - you would have to check that out and I suspect it's not possible. Which means you'll have to press fit a sleeve into the prop and bore out to suit - which probably won't be worth it either compared to a new prop ready bored.
alahol2
22 Apr 2004
Portchester, Solent
www.troppo.co.uk
Talk to Portchester Engineering
17-19 Windmill Grove
Portchester
Fareham
PO16 9HP
Hampshire
Tel: 023 9237 4771
Fax: 023 9221 9253
Made me a new propshaft at very reasonable price within 2 days of request.
