paulbevan
New Member
Hi, does anybody know if the Mariner F15ML (serial number OR359696 - I think it’s a 2010 model) can be converted from tiller to remotes?
thanks
thanks
I’ve never done it to be fair. But certainly know you can. You’ll need to fit a steering tube, bar and cable system for the remotes. Also the throttle and gear remotes kit too. As you have it now. There should be a blank fitting where the remotes for gear and throttle would go. Alternative is a cheaper system for gear that goes directly onto your gear lever.Thanks QBhoy, I take it there’s a standard conversion kit available?
