Connecting XM DSC radio to Garmin GPS
DavidGrieves
13 Aug 2001
West Cumbria, Cumbria
www.wsandba.co.uk
Hi All
Trying to help another boat owner, He has a Garmin 128 GPS and wants to connect it to his XM DSC VHF radio.
I thought I had it sorted but it doesn't always work.
I connected the blue NMEA out from the GPS to the Yellow wire on the radio and the black wire NMEA ground to the green with on the radio.
It does work sometimes and radio shows correct position and time. But sometimes they stop talking to each other and radio says no GPS.
Any ideas???
Chreers
Dave
Loose connection/broken wire somewhere?
Richard
Indeed
If you connect both NMEA -ve to a common ground and then+ve connections to each other, it will work this is simple and old equipment. Suspect the OP’s pal has bridged the -ve connections together and then both to ground, it should work but he has two connections to be dodgy and interrupt the signal.
Usual riders about a common ground (same battery/batteries), baud rates and garmin versus NMEA out apply.
Hi All
Any ideas???
Chreers
Dave
Blue to Yellow is correct. At the VHF, you can simply connect the NMEA IN - (green) to the 12v negative, or any convenient 12v negative. If it works sometimes the baud rates and setting will be correct, it has to be a bad connection, as per post #2.
interesting thread, I had the same question
