roly_voya
I now have most of the electronics in boxes in garage ready to fit after christmass but have been looking at how to wire it all together /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
I have a JRC JMA-2343 which should connect to GPS, heading sensor and send out the curser position. Also have Garmin GPS172, raymarinte ST400+ autopilot and will be using a Dell laptop for nav which doesnt have a serial port (has lots of just about everything else!!!).
1 - I want to connect the GPS to both the radar and the laptop so that they all share the same way-piont database?
2 - The 'dataout' for the curser display is two wire (data +&-) but there is no indication in the manual how you feed this to a computer?
3 - Againe the heading sensore has two conections +&- do these hook directly to a heading sensor or to the NMEA conections of the autopilot head?
4 - Should I be looking to make all the connections as individual links or would it be better to get sothing like a NMEA hub and connect everything to that and let it sort out who wants what data?
I am reasonably good with electrics but never done anything with NMEA networks - is it reasonable to expect to be able to do this or should I call in an engeneer to set it up?
