anniebray
My Sadler 290 has a 150lt flexible water tank which we find inadequate. I would like to investigate fitting an additional flexible tank under the cockpit floor (ie under the bunk in the aft cabin). I would prefer to T into the existing tank outlet to pump hose which is I think 15mm & use a single 15mm hose to the new tank for the dual purpose of filling & delivery rather than have the aggravation of extending the 50mm dia hose from deck filler to existing tank. The new 15mm hose would be routed low as possible & connect to the underside of the new tank. Question is would 15mm be too small for the filling hose ?
