drewstwos
Confused, you bet\'cha! Please sort this one out. Help!!
HI all
At the end of last summer I decided to re engine the boat, as the little 50 hp was just not man enough to cope effectively with the tides and currents we get here on the Isle of Man. I have now installed a 160 hp turbo beast which is now lined up and bolted very firmly down.
So the next thing to do is sort out the prop, and here’s the conundrum.
I contacted two very well known firms, both recommended by forumites who had had excellent service.
I was baffled before, but now I am totally confused. Why?
Well. The old engine had a 19 by 11 prop, turning at 3000 rpm giving a mighty 6.5 kts. Boat a 27ft Aquastar, beam 10ft LWL 25.5 ft weight 4.5 tons draft 3.25 ft gearbox ratio 2:1.
But…and here’s the rub
New engine turns at max 4250 rpm 2.13:1 gearbox
One set of figures for the new engine ..a 20 by 14, and the other 18 by 12. So which is right? You can see now why I am totally confused. One over the original and one under.both suggesting a tad under 16 kts
Being a poor old pensioner, getting it wrong at about £500 a pop (prop..excuse the pun) would be painful to say the least.
So, my most wise and experienced fellow forumites, your thoughts and conclusions would really be much appreciated.
I look forward to some very interesting replies.
Over to you……………
Cheers /forums/images/graemlins/mad.gif
Drew.
HI all
Over to you……………
Drew.
