Confession
jimi
19 Dec 2001
St Neots
Do'nt know if I should share this with you ... but ... I found another battery on the boat last weekend .. instead of the 2 75A 600Ah I thought I had, I've in fact got 3. One was hidden under a bunk and was discovered when I was checking the propeller shaft seal ...
tcm
11 Jan 2002
Caribbean at the moment
Yeah very funny. Don't tell me - you thought that the original couple were exclusive hooked up and now it seems as though the battery hiding under the bed is going to start something!
Spacewaist
1 Oct 2002
UK
blog.mailasail.com
3 x 600 Ah?
What kind of boat U got?
1800Amp Hours of power is enough to run a navy.
A pontification from the Panjandrum of orotund bloviation AD2002
jimi
19 Dec 2001
St Neots
blow me down with a feather
Bugger me! You mean I've got it wrong again! Maybe I'm using batteries as ballast! Sod it there was me busy copying the numbers off the case and I've still screwed it! What does the 600 mean .. they're Tudor Z10 batteries .. I'm off to the pub!
Jim /forums/images/icons/frown.gif
TheBoatman
12 Nov 2002
Kent
Well at least I know whom to contact when I need to jump start my Jumbo<s>.
Either that or you could hook it up to a big light and anchor your boat next to the Tricolor and make like a lighthouse, maybe then they might stop bumping into it?
