Graham_Wright
I've bought the tester and done the tests.
What figures should I expect. All cylinders seem about the same.
I would talk to Thornycroft who were the original sellers of these marinised BMC diesels. If they are all the same the engine is probably OK - when I did this years ago, 2 cylinders were well down which probably explained the poor starting(as well as only 2 heater plugs working) and the clouds of smoke when motoring off!
What figures should I expect. All cylinder seem about the same.
Compression ratio on 1.5 is 23:1 so ignoring the pressure rise due to heat of compression, you are looking at about 325 psi.
=15*23 (roughly)?
Should I have known that?!
I don't understand why there would be a correlation between engine size in metric units and compression pressure in imperial units?
If the compression ration is 23:1 and it starts off at atmospheric pressure, 14-odd psi, then after compression 23 times the pressure would be 14 x 23 = 322 psi.
Richard
I checked again last night. Maximum reading was about 240. The engine was cold and the cylinders maybe not thoroughly oiled or am I clutching at straws? The reason for checking was that it fires after a good bit of cranking on one cylinder, then slowly picks up on the others. When warm, it starts immediately.
Did you carry out the test withh all of the injectors removed as engine has to spin pretty fast. I have tried to find the actual figure but failed. You should contact Calcut who rebuild 1.5s
If you are unhappy with the compressions you could do what engine tuners do, take the head off and have it skimmed, that would increase compression, you could also do a de-coke and re-grind the valves in.
I didn't know if I was happy or not as I didn't know what the readings should be which is why I asked the question.
I contacted Calcutt (who do reconditioning) who advise that a reading around 400 should be achieved with a cold engine and 280 when hot.
It seems my engine figures are down.
I had a 1.5 many years ago which came out of a J4 van so was pretty long in the tooth when I got it but I just put on the Marinizing bits and was ok to start with but a bit slow to start.. Eventually I pulled the engine out of the boat and did a partial overhaul which was to regrind the valves, new bearings and new rings with a quick hone of the bores. Was better but still a bit slow to start as needed over 30 sec on the glow plugs.
One thing which puzzles me about your engine is that it starts on one cylinder. As all your pressures are similar, it would suggest you may have faulty glow plugs or a couple of gunged up injectors or both. One point about the glow plugs is that (I was told but not experienced) glow plugs can look ok in terms of continuity but have actually an internal short so they look ok on a meter but don't actually get hot. Best test is to pull them and see if they actually glow. Better still bang in a new set at £25 of ebay.
One other way of getting an old engine to start is to fit a "Thermostart" as fitted to Perkins 4108 etc. This is a unit fitted into the intake manifold which vaporises a small guantity of diesel to help the engine fire. Needs a bit of plumbing and possibly a small tank of about a litre to gravity feed the Thermostart.
Best of luck.
