burgundyben
Since the boat sank a couple of years before I bought her, I feel the need to do a complete rewire.
She is a twin engine semi-displacement motorboat 31ft.
Here is my plan.
12v starters and alternators. Starter motor relays
One battery for engines - Numax CXV24MF with 780 CCA (manual says it needs 695 CCA) - to Minimise cable lengths this could be mounted centrally
Batteries 3 in parallel for the domestics - Humax CXV24MF 80 amp hour
Port engine alternator charges the engine battery.
Starboard engine alternator charges the 3 * domestic batteries.
Solar panels on the wheelhouse roof with MPPT controller outputting to the domestic bank only, wired so working while isolators are off. Sized to be able to run fridge all day in summer without losing charge.
Anchor windlass 1000W 12V
2 isolator switches one for engine battery, one for domestics, both mounted in wheelhouse on bulkhead by the door (Durrite 0-605-50)
Third isolator under the floor out of reach which connects domestic bank to starting battery if needed. (Durrite 0-605-50)
Dometic CRX50 fridge - 5 amp draw, 15amp fuse for inrush, need to size solar panels to run fridge
Inverter - 2000watt?
5kw diesel Chinese heater outlets in cabin, heads and wheelhouse.
Electric bog.
Bilge pumps? 3 auto, aft, mid, fwd. Connected so always on regardless of isolator switches
Horn
Flood light
Freshwater pump
USB Charging
Wipers
Washer jets
Dash
Tachos
Fuel tank gauges
Engine Temp
Engine Oil Pressure
Ignition switches
Charging warning light - route to the alternator exciter
Exhaust alarms - Aqualarm - already onboard
Engine box fire alarms - Aqualarm already on board
Nav/Comms
VHD DSC - Standard Horizon
AIS - RTE?
GPS - SOG, Waypoints, MOB, position
Log/Echo - paddlewheel - NASA Clipper Duet
Lights
Cabin
Heads
Wheelhouse
Red night light in wheel house
Cockpit
Underwater
Nav lights - reg/green/steaming, stern anchor
Flood light for cockpit
Underwater LED at transom.
Comments?
Here is my plan.
Electric bog.
Horn
Flood light
Freshwater pump
USB Charging
Wipers
Washer jets
Dash
Tachos
Fuel tank gauges
Engine Temp
Engine Oil Pressure
Ignition switches
Nav/Comms
AIS - RTE?
Lights
Cabin
Heads
Wheelhouse
Cockpit
Underwater
Comments?
