Snowgoose-1
My liquid compass bulkhead compass is cloudy plus low fluid. I have numerous ways to know where going inc hand bearing. I only deem to use it occasionally for tacking angles. Does anyone still check it annually ?
On a coaster the compass developed a big bubble we tried Gin which worked if I recall took a lot of fiddling to inject the Gin inMy compass suffered a loss of fluid from a faulty seal - I replaced the seal and I refilled it with Baby Oil - yes is is the correct fluid to use and cheaper and easier to find than "proper" compass damping fluid. I wouldn't be without my bulkhead compass - an essential piece of kit in my opinion and use it all the time.
I topped up with baby oil some time back.Nice for a while but now too frothy. The compass, Contest 100, has a brass screw where liquid can be added/taken away. Any ideas what the real stuff is and where to get it ? Might be worth a try . Have googled a bit but nothing clear cut.My compass suffered a loss of fluid from a faulty seal - I replaced the seal and I refilled it with Baby Oil - yes is is the correct fluid to use and cheaper and easier to find than "proper" compass damping fluid. I wouldn't be without my bulkhead compass - an essential piece of kit in my opinion and use it all the time.
Gin was also used to clean periscope windows on submarines prior to diving. Often more gin was used than....used if you know what I mean.On a coaster the compass developed a big bubble we tried Gin which worked if I recall took a lot of fiddling to inject the Gin in
I lapped my Blakes sea cocks with toothpaste a couple of years ago. It's very useful stuff.If your boat compass looks cloudy, a tip I was given, have used and passed on is that toothpaste and a cloth is a great restorer of clarity.,
Brasso wadding works brilliantly too, or headlight "clarifying compound" if you happen to have it lying aroundIf your boat compass looks cloudy, a tip I was given, have used and passed on is that toothpaste and a cloth is a great restorer of clarity.,
Same here. So far done 16k miles on this boat, but less than 200 when the cover has been removed from the magnetic / analogue compass. The only situation it is used is in very thick fog and swirling tides - eg when leaving an anchorage close to Corryvereckan in thick fog.Haven't yet taken the cover off the compass this season. We have a digital heading display which is better for our purposes. The good old fashioned analogue compass is reserved for electrical power failures.
