Compass light
Jack B
13 Apr 2011
River Stour
Hi,
I have a bulkhead mounted compass on my boat, however it has no light, has anyone got any tips on how to light it cheaply?
Thanks Jack
Hi,
Thanks Jack
By bulkhead mounted do you mean a flush fitting port hole type or on a bracket on the bulkhead.
FWIW I have a grid compass above which I have fitted a domed panel light with the lens half blacked out and fitted with a 24 volt bulb.
Unless it's a very strange one it should have a built in light. Some installers don't bother to connect them and just leave the wires concealed. Try taking it out to see if there's anything there. I connected mine (Silva) to the nav and steaming lights using diodes so I didn't have to use a separate switch.
If no light just use a torch?
Unless it's a very strange one it should have a built in light. Some installers don't bother to connect them and just leave the wires concealed. Try taking it out to see if theirs anything there. I connected mine (Silva) to the nav and steaming lights using diodes so I didn't have to use a separate switch.
No doubt later on this arvo we will gleen what make it is
Should have said it is a plastimo, not sure what model though. I will have a look this weekend to see if it actually has a light hidden away.
Thanks for all the advice
Most Plastimo compasses have an expensive little grain of wheat bulb on a twisted pair of wires. If you have to replace it or fit a new one the wires must be twisted otherwise the current might exert magnetic influence on the compass. With an LED the current is muck less so it probably won't matter in that case. See this page for bulb part numbers (scroll down). http://www.theyachtshop.co.uk/items/navigation~electronics/compasses/compass-accessories/list.htm
Yes, and the little blighters tend to burn very bright.
One way to dim them is to give them a thin coat of red nail varnish, which is the cheap solution.
The expensive solution is to fit a dimmer switch, ouch !
A cheaper way would be to put a resistor in series with the bulb.
When my compass light failed I bought a replacement from ebay but 24v version so it is much dimmer but should last a long time - I did find the original 12v bulb was too bright.
You can get the tiny grain of wheat bulbs (incandescent ) however LED is the way to go. One LED (diode) should suffice. A good source might be an old solar garden light even new they are crazy cheap around here. (1 squid). You need a resistor to run it off 12v I would suggest you buy resistors in the range 560 ohm 620 ohm 750 ohm 820 ohm and 1000 ohm. in 1/4 watt size. Try each out to see which one suits for the amount of brightness you want. Polarity is critical on the LED.Just be aware when you mount the LED that the light comes out in a beam from the domed end so you need to point it at the card, unlike an incandescent lamp that shines in all directions so orientation doesn't matter.
good luck olewill
good luck olewill
we have a retailer here ( Maplins ) who stock LEDs that run on 12v @ about £0.80 a pop
