ChathamSailor
Active Member
Is neatly £400 the charge for a compass adjuster? If so is it not cheaper to just buy a new steering compass ?
A new compass must be adjusted to the boat (mag field unique to the location on the boat).Is neatly £400 the charge for a compass adjuster? If so is it not cheaper to just buy a new steering compass ?
I have done this and produced the card, but the errors are large, hence the need for magnets which I cannot do.A new compass must be adjusted to the boat (mag field unique to the location on the boat).
That said, it's not that hard to do yourself. Read the instructions. Traditionally, you go out and motor back and forth on some measured ranges, at 90 degrees. Remember, you are adjusting the compass to the local earth field, not to a GPS course, since they are not the same.
I did this once, over 40 years ago. I bought a small book with a catchy title something like ‘Compass adjustment’ and learned about the different coefficients that needed to be corrected. Although a proper adjustment is clearly a complex and skilled business, in practice you only need to correct for the two coefficients that are maximum at N-S and E-W to get a satisfactory result.I have done this and produced the card, but the errors are large, hence the need for magnets which I cannot do.
