Comparing wet to dry batteries?
Colvic Watson
23 Nov 2004
Norfolk
I’m getting my watts mixed up and fack to brunt.
I want to compare the useable capacity of wet lead batteries to LiPo. Taking each of the 100ah lead acid batteries which have about 60Ah of useable capacity. At 12.5v that’s 750w.
Now I’m thinking of adding a power station which has lots of different outputs but that’s rated at 230v and has 1.5kwh of useable capacity.
I know I’m comparing an apple to an orange but what’s the comparable energy amount?
Thank you!
PaulRainbow
16 May 2016
Suffolk
Max sensible discharge from LA batteries is 50%, so your 100ah batteries have a usable 50ah. Watts do not come into "usable capacity".
Thank you!
How are you converting 230v to 12v ? If that's part of the power station there will be some losses. Without more detail it's not possible to make a comparison.
Link to the power station ?
VicS
13 Jul 2002
Thank you!
Taking your figure of 60Ah useable capacity, at 12.5 volts that's 750wh or 0.75 kwh. That is half of the usable capacity of the "power station".
Colvic Watson
23 Nov 2004
Norfolk
Thank you. So watts are the key? Just compare watt to watt and ignore the volts? In my muddled mind I was assuming that 1500w at 230v was more than twice the power of 750w at 12v.
Thank you 👍🏼
PaulRainbow
16 May 2016
Suffolk
Thank you 👍🏼
As i said in my earlier post, watts are not a measure of capacity. Ah or Wh are.
simonfraser
13 Mar 2004
Just compare watts from the different supplies that will give you a guide
It’s obviously over time, so you should think about Wh = watts per hour
How many watts you can get out of a battery varies with capacity, from the main likely indefinite
S04
27 Jul 2024
Well not really, if it was Watts per hour it would be written W/h. A Watt is a Joule per second therefore Watts per hour would be Joules per second per hour. Wh is Watts x hours not Watts / hours.
PaulRainbow
16 May 2016
Suffolk
Noooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo
A Watt is a unit of power.
A Wh is a unit of power. 1 watt for 1 hour is 1 Wh.
No. You can get the same watts from two different capacity batteries, just not for so long.
simonfraser
13 Mar 2004
Yeh we’ve had this discussion b4, for the lay person, inc me, a watt from the power point at home or my boat battery is the same amount of energy
So if I want to compare the mains supply or batteries I use watts, per / over whatever seconds hours joules etc 😉
Alex_Blackwood
19 May 2003
Fareham
Thank you!
Don't really have any idea what you are on about. However I suspect that you are trying to compare LA batteries to a "PowerStation" containing LiPo batteries.? :unsure:
Watts= Volts X Amps. Etc.
With your 12.5 volt 100ah LA battery having a useful capacity of 50ah, If you run a load of 625 Watt (12.5 x 50) it will last for an hour.
If your "Power Station" has a capacity of 1.5Kwh @230 volts, it will provide 6.25 amps for hour into a 1.5Kw load. If the internal LiPo battery is 12.5 v. it will provide 120 amps. (120 ah) for that hour.;) (NB. Half an hour for 3Kw.)
Does that help?
PS You would need at least 240ah LA battery to run the "Power Station" at 1.5Kw for the hour.
PaulRainbow
16 May 2016
Suffolk
Without providing some information as to what this "Power station" is, this thread is largely pointless. It's even more pointless without knowing the OPs intended use and how he'll charge it.
It sounds like it might be a IfheP04 battery in a box, but if it outputs 240v it must have in inbuilt inverter, which will have losses, typically 10%. If it's only intended for 12v systems it's a waste of an inverter, the OP only needs the LifeP04 battery.
More info needed........................
Sandro
20 May 2004
Northern Italy
I may be dumb but I could not understand what the OP is looking for.
There is a thick fog.
If this can help:
ENERGY: Joule, W*h, kW*h, kgf*m, Lbs*foot, torque*angle, money, capital, £.
POWER: W, kW, Joule/sec, kW*h/h, kWh/day, HP, salary, wages, rent, £/month, $/week.
Please do not mix up.
AngusMcDoon
20 Oct 2004
Up some Hebridean loch
If this can help:
You forgot one - in the FFF system power is firkins times squared furlongs per cubed fortnight. I tried to work out the scaling factor to kW but it made my head hurt and after a couple of dozen microFortnights I gave up.
Colvic Watson
23 Nov 2004
Norfolk
Here’s what I’m trying to compare: a power station that has a useable capacity of 1.5kwh at 230v
Vs lead acid batteries through an inverter.
To get the same 1.5kwh from lead acid am I right in saying that I’d need three 100ah 12v batteries? i.e. 3x50x12?
Of course the power station has significant advantages, it’s lighter; has lots of charge/discharge sockets; and crucially can charge its full capacity in 70 minutes. Doing that with lead acid would boil the acid off.
