tom52
1) Is it reasonable to assume that twin 150HP shaft driven engines at 3000rpm will produce the same speed as a single 300HP engine at 3000rpm on identical hulls? Or are their significantly different losses from friction etc between engine revs and push at the props for single and twin set ups ?
2) If I look at the power performance curve of a 300HP engine and read off the l/hr at 3000rpm and compare it with the l/hr (times 2) of a 150 HP engine at 3000rpm am I comparing like with like ?
