Gerry
Has anyone experience/advice on doing this? This is a seacock is for the shower drain pump outlet and discharges above the water line. Is there any reason that I can't just screw them together with PTFE tape?
Not sure why you would want to do that - but you may find the Tru Design composite valves and fittings more suitable. However the simplest replacement is a DZR valve, although above the waterline that is not critical.
Is it harder than bronze?>A bronze fitting can easily chew the threads on a plastic one.
Marelon is not plastic it's a very hard material made of nylon and GRP.
Don't think so. Pipe fittings have BSP threads.Check thread compatibility. Marelon might have American standard UNF thread and bronze skin fittings normally have metric threads as they are often made in one foundry in Italy.
Apparently there is also the NPT thread on American fittings available from ASAP.
