coopec
N/A
Is it important to have red courtesy lights on the stairs to avoid destroying night vision or is that a myth??
No, not a myth. Night vision (scotopic vision) is mediated through rod cells in the retina and is colourless. The cone cells, which give you colour vision, don't function at low light levels. Rods are most sensitive in the blue/green segment of the visible spectrum and are insensitive to red light. Night vision takes time to adapt when moving from a light environment to the dark (5-10 minutes - longer to optimal performance), but is immediately supressed going from dark to light. If you use red light below decks and in cockpit instruments you will not interfere with rod adaptation, and so preserve scotopic sensitivity. If you use white light, your vision will have to dark adapt again every time you return to the cockpit. There may be good reasons to use lights in the cockpit at night, but you can't have optimal night vision and lighting that isn't red.Latest information is that red light is a myth - all that matters is the brightness and the traditional red night lighting worked because it was simply dimmer than the white.
No, not a myth. ... Rods are most sensitive in the blue/green segment of the visible spectrum and are insensitive to red light...
Quote from that page:I was thinking of this: http://stlplaces.com/night_vision_red_myth/ but I'll freely admit I'm no expert.
Colour of stairway courtesy lights.
I read this and was puzzled by his claims and the basis for them. Dark adaptation is a two-stage process. Firstly, the cones adapt so that you retain colour vision. Then, when the light level is too low for the cones, the rods continue to adapt. At that point you lose visual acuity and have a very small foveal blind spot. It is only the very centre of the fovea that has no rods, and that rod-free zone is less than 0.5 mm in diameter. The loss of visual acuity arises partly because rods share neurones, so information passed to the brain comes from a cluster of cells rather than a single cone, partly because rods are thinly spread around the fovea, and partly because of diffusion of light through other structures which are absent in the centre of the fovea. It's fair to say that visual detection within a central 10 to 15 degree cone will be very poor.I was thinking of this: http://stlplaces.com/night_vision_red_myth/ but I'll freely admit I'm no expert.
Wow great post Andy.
Yes, that's correct.i.e. the peripheral vision will pick something up whereas looking directly at it, one will not see it. I think this is correct because I often see things at night with my peripheral vision and do not see it when I turn my eyes to look at it.
I was trained that at night to use the 'figure of 8' motion with my eyes when trying to keep a lookout - i.e. the peripheral vision will pick something up whereas looking directly at it, one will not see it. I think this is correct because I often see things at night with my peripheral vision and do not see it when I turn my eyes to look at it.
But then that could just be me with squiffy eyes![]()
Don't think it's just you
We were taught the same thing in Cadets at school. Also to close the right eye to protect its night vision when a bright light appeared. Always the right eye, so that you could still see through a rifle sight when the dark returned. I still do that.
Unless Of course you are left eye dominant and shoot off the left shoulder!![]()
