cold engine
kevin2
10 Jan 2006
Isle of Skye
I have a ford new holland 160hp wich has stopped going up to its working temp it has only 500 hrs on the clock so seems strange, have changed the thermostats and the sender and switch, changed the gauge as well, still the same, can anyone suggest anything else.
kevin. /forums/images/graemlins/confused.gif
Does it <u>feel</u> hot to touch ?
What sort of indicated temp are you getting ?
Have you changed any cooling valve positions ?
Is it indirect or direct cooling ?
Has the ambient temperature changed dramatically since it was running hot ?
No not hot to the touch - this is a twin engine installation and the Stb'd engine is hotter to the touch. It's the Port engine that's cool.
Temperature is usually 85 degrees C (now 70)
No change to cooling valve positions
Cooling through heat exchanger
No to dramatic temp change.
Thanks for your help - keep it coming!!!!
Just a thought and a very long shot but has the heat exchanger got a problem if raw water is by passing the matrix somehow it could be keeping the temps down
Ok thanks for that, have orderd a laser thermomter from maplin will check around the block. Will also drain exchanger start engine and see if salt water comes in from matrix. Could it be a problem with the engine fresh watre pump?
Hi, Will try turning off the flow,(Do you know why this would make a difference)
The engine is heating the 40ltrs of very cold water.
No need to drain down to see if sea water is getting in the header tank just taste it, sea=salt antifreeze=sweet. Probably down the hot water system, and the ambient temprature outside.
