Q
quimby
What would be the result of replacing a faulty coil in a 2hp yamaha outboard with one of another make providing I can fit it beneath the Flywheel? motor is a Yamaha 2A
If you are talking about one with points ignition then it would probably work provided you found another from a points ignition engine that fitted properly
They fit with very small clearances between the pole pieces and the flywheel magnets. Special tools are available to fit them correctly
