Frank mellin
Am getting to know the westerly centaur i bought recently.
decided to clean the cockpit area with jetwash and was surprised to find that it started to fill with water!!
Have had the boat for couple of months and no problem previously so can only assume that in my wisdom I have jetwashed some muck into the drain holes .
Have tried pressure to clear and pipes are clear down to seacocks so seems blockage is in the outlets.
Has anyone had this problem and cured it without taking the boat out of the water
Also there is a 10mm copper pipe that runs from the Nanni engine into the cockpit floor which when the engine is running pumps out water.
As there is an exhaust/water outlet on the stern which discharges the water from the cooling process what is the water that discharges into the cockpit?
Grateful for any help
