Cockpit Table req.
itsonlymoney
21 Jun 2003
Can anyone suggest a supplier of a small pedestal type table suitable for my cockpit. Have seen them in an American catalogue "Allertons" postage is high though. Also tryed motor caravan dealers they have the pedestal but not a plastic table top, floor plate also needs to be small and not cut into floor as fuel tank is were I want to mount it.
Thanks in advance of a reply
Ian
<hr width=100% size=1>I'd rather have a bad day boatin, than a good day workin ! ! !
martynwhiteley
18 Aug 2001
North Lincolnshire
www.towsure.co.uk
They have the pedestles and mounts, use a table mount upside down to attach to the floor to avoid a cut-out.
Then just choose a white plastic garden table for the top only. You may have to make a ply disc to fit under the plastic top to fix to the pedestle mount.
Should only cost about £25 in total.
<hr width=100% size=1><font color=blue> <A target="_blank" HREF=http://www.mboat.org>http://www.mboat.org</A></font color=blue>
MLBURGE
24 Jul 2002
medway
i am in the process of making a range of fibreglass moulds two of which are exterior tables, they are rectangular in shape with a slight curve to all sides and the edges have a moulded fiddle rail incorperated in a half round curve - similar to the cockpit tables found on most new boats. The smaller mould is almost finished and measures approx 18" W x 31" L larger is still in design, a moulded 9.5" disk is moulded in to allow fitment to most production pedestals.
PM me if this is of interest to you or if you want to see design or photos by email.
MLBURGE
24 Jul 2002
medway
I am in the process of manufacturing a range of fibreglass products two of which are exterior cockpit tables they are rectangular in shape with a slight curve to all sides and the edges incorperate a moulded fiddle rail in a half round curve - similar to the tables found on most new boats. There is a 9.5" disc moulded to the underside to allow fitment to most production pedestals.
The smaller mould is almost finished and measures approx 18" w x 31" length the larger is a little way from completion.
PM me if this is of interest or if you want to see design or photos be email.
