RJJ
Hi everyone. Skin fitting project continues...now onto the cockpit drain which gives me another puzzle. The current arrangement is both sides join in a Y to a single tube, which then exits via a 90 degree plastic skin fitting below the waterline. Just off-centre, with no ball valve of any kind. There's not much "drop" between the drain and the skin fitting.
I am unhappy with this, particularly the last part. Questions, please:
1. Is a plastic skin fitting below waterline ok? I was minded to replace with DZR or fibreglass, but have yet to identify a 90 degree one...implying if I change it, it has to be a vertical fitting that will affect the (already-limited) drop.
2. Am I right in thinking a ball valve is essential, being below waterline? True that the valve would always be left open unattended...
3. If I changed the layout (to skin fitting/valve/90 degree tail), the hose would no longer be a direct downward path to the sea...but since it's below the waterline, perhaps this doesn't matter?
Any thoughts, or other options most welcome.
