cmap ecs 4.1
henkv
New Member
2 Apr 2006
I"ve got Cmap ECS 4.1 with Cmaps c93, the program works excellent, but doesn't find my connected GPS. An other program WinGps works without problems with my GPS. The Prolific GPS is connected USB to serial. When I disconnect the GPS, ECS 4.1 says NMEA port dosn't openend. Do anybody knows how to handle this?
Henk
Henk,
If you start up the config file in 'navigator', open the ECS configuration file you can find there. Then go to the NMEA configuration screen. There select the right com port (you know which com port your GPS is using, I presume?). The NMEA tokens should be RMC. And while you're here, deselect the autopilot in the next screen.
Cmap, Wingps and waypointgps all work fine in my laptop, so it's not the fault of the programs.
Good luck,
Chris
