Clyde to Scillies passage, recommendations for stop over places in Wales?
West Coast
23 Aug 2009
Clyde
Plans coming together for a 2 month trip to France this summer from home berth in the Clyde. Will take 10 - 12 days for outward passage to Brest in early June, so can see places on the way. Day 1 will be passage to Bangor in N Ireland to pick up some crew. From there, thinking of heading to N Wales area (Holyhead?) then to S Wales area before heading to the Scillies. Thinking of the Wales coast rather than the Irish coast as have never been to Wales.
So question for those who know the Wales sailing areas - where would you aim for in N Wales and similar for S Wales as good stop over points?
[2574]
29 Nov 2002
Be aware that the locals prefer “Isles of Scilly” or plain “Scilly“, at least that is what I’m told that is the preferred vernacular.
TSB240
17 Feb 2010
Our short daylight passage route would be Clyde, Port Patrick, Peel or Port St Mary IOM. Moelfre, Porth Wen, Cemaes, Holyhead, Rhoscolyn, Porth Dinllaen Depending on wind direction North Wales. Dale in S Wales.
Padstow to IOS
Or cut out Dale and Padstow and head for Kilmore Quay direct from North Wales then direct to IOS.
Supertramp
18 Jul 2020
Halifax
Aberdaron is a useful passage stop at the tip of the Llyn peninsula for W/N winds.
Pwllheli is sheltered but only all tides for shoal draft or at neaps and is a detour.
Greystones is an easy all tide access marina.
Much obviously depends on winds. If W then the Irish coast has lots of shelter for an overnight at anchor. If E or N then the Welsh coast is better. I use overnight anchorages to catch sleep and the next favourable tide.
oldmanofthehills
13 Aug 2010
Bristol / Cornwall
Padstow to IOS
Dont bother with Wales except for Milford Sound, its often a lee shore with large deviations to harbours, and only Fishguard is really on route. The tidal gates of Ramsey Island and Jack Sound are interesting enough but can be hard to avoid as avoidance places one in dangerous races or cluttered reefs and islands
Even in an easterly the offshore banks off southern ireland give moderately sheltered water unless you are foolish enough to try crossing banks in the shallower channels.
Peel in IOM very nice but I would tend to go straight to Glenarm or Bangor (eir) and follow irish coast down to Arklow, cross to Milford, (anchoring under Skomer if you fancy stopping before but Dale worth a visit inside Milford sound) then direct to Lundy, then either St Ives or direct to Scilly. With enough crew I would probably go Kilmore Quay to Scilly, however 2 up and ancient we chickened out of it.
We chose that route on our 1500nm tour of inner hebrides last summer, starting from S Cornwall, as our previous experience has shown east coast ireland both easy and pleasant with readily available chunks.
Concerto
16 Jul 2014
Chatham Maritime Marina
True, but you can only anchor in Dale, Lundy, St Ives and Scilly and have to anchor in the Camel waiting for Padstow. Normal Englishside Bristol Channel and West Wales type problem.
There is a pontoon at Dale you can moor alongside which is not connected to the shore. It has a white all round white light to help find it amongst all of the anchored boats. Used it last year.
oldmanofthehills
13 Aug 2010
Bristol / Cornwall
And in bad weather the outer pontoon leaps like bucking bronco so you are better of anchoring (which i think you are not meant to) or picking up mooring. As we can take the ground we normally use the finger pontoon unless we need to leave at LW. Easier access to the Griffin
lustyd
27 Jul 2010
Not true. The locals literally wear Scillies t-shirts and hats and sell them in the shops. They're very friendly regardless of what you call their home, within reason.
john_morris_uk
3 Jul 2002
At sea somewhere.
Regarding the leg from S Wales to Scillies/Lands End, I would be very careful about going up as fas as Lundy. We’ve always gone straight across. Why get embayed against the prevailing wind?
The passages inside Skokholm and Skomer just need timing right to catch the tide. No great shakes. We’ve anchored in Fishguard and Milford in the past but the advice on the pontoon off Dale is also good.
SaltyC
15 Feb 2020
Yorkshire
If you are going to Bangor I would seriously consider going down the Irish East Coast to tge SE corner - Wexford or around onto South Coast then the Scillies. The East Coast is in the Lee of prevailing Westerlies and gives 'wasting ' for the Scillies.
lustyd
27 Jul 2010
Yes, quite a few times, and most summers recently. They tolerate Scilly Isles but prefer Isles of Scilly. We dry out in Green Bay but explored back of great arthur last year and enjoy the bistro on St Martins etc
Must be the way you say it, they’re always very happy when I speak to them.
