smb
I have been drawing water/fuel from the bottom of my tank today. After a cup or so of what was clearly water, I have taken the next c25 litres of fuel off the bottom and decanted it into clear poly bottles. After a while a little water (a drop or two) settles out, but the fuel is quite cloudy.
Following a search on here I found an old thread that said I should try warming it to see if it clears. An hour in the Med sun (Kalamata) and its cleared nicely, depositing some more water droplets in the bottom of the bottle.
Question is, if this fuel is holding water is it safe to continue using it and monitoring the water trap, or would it be better to draw out the remaining 130l and leave that in the sun litre by litre to dry? Other than fuel (mostly bought at sevice stations) nothing else has been added to the tank since 2008, when I stopped using starbrite bio diesel on the advice of the local bosch specialist who suggested it might have been responsible for my injector pump rusting and then seizing. Naturally I dont want that to happen again.
Steve
Steve
