Robin
Our Jabsco twist 'n lock sits on a sort of raised ledge in the shower/heads. The inlet and outlet pipes both pass through a sort of keyhole shaped cutout hole in the fibreglass floor of the ledge and access around the rear of the bowl an pipework for cleaning is very restricted. When water from a shower finds it's way down the cutout hole for the pipework it takes a devious route to the bilges and even more so to the bilge pump sump. When we had a similar arrangement on a Beneteau Oceanis 36CC in Florida our local loo guru fabricated a cover plate to close off the hole but it would be hard to design /fit something similar here as the access is very difficult. It would be nice to be able to use the shower hose to sluice down and around occasionally without it dripping into bilge When showering too it would remove the need for the claustrophobic encircling shower curtain and even allow a sit down on the loo seat shower with all water going straight to the shower tray from where it can easily be pumped out.
Anyone any ideas? I thought about using expanding foam sealant or even a sort of wetsuit material 'mast coat' cone.
All suggestions gratefully received!
