Pkewish
I recently fitted a through-hull (I always get confused with these, one which reads through the hull, NOT mounted through the hull) transducer and display. I followed all the instructions to the letter. i.e. mounted away from electrical bits and bobs, in the middle of the boat, pointing down etc etc. I have checked for air bubbles in the caster oil by pushing the transducer down so that oil comes over the top.
The problem is - it only ever reads 1m to 1.2m. The little arrows showing 'getting deeper' or 'getting shallower' ping up periodically, I have reset it etc etc.
The only guess is that it is fitted over an air bubble in the foam between the 2 skins of GRP. Should I replace for an in-hull transducer or does anyone have any other ideas.
Cheers
Cheers
