peterandjeanette
I need to check several batteries in our boat.
The main engine starting battery ( 12V 110 ah ) seems fine.
The domestic batteries ( 4 x 12V 110 ah - same as engine starter battery ) seem to deplete fairly quickly. Each battery needs testing. They are all sealed so I can't use a hydrometer. ( I did discover that one battery was heavily corroded round the positive terminal to the extent that the clamping bolt was almost gone. No problems with the others )
I've looked at the Clarke CVT1 battery tester. Has anyone ever used one of these and if so what are your thoughts? Can it be used on sealed batteries?
All replies gratefully accepted.
