kalanka
I have pulled the 1 inch propeller shaft on my boat (Sadler 34) prior to fitting a new cutless bearing and bought a 1" x 1.5" x 4" Vetus replacement bearing in a bronze sleeve.
When I hand fit this to the shaft there is a certain amount of play in the fit - I estimate 0.5 to 1mm at the bearing with light hand pressure.
I expected a rather tight fit that would free up in use. When I measure the shaft with a good caliper it measures 25.31mm - which is less than the nominal 25.40mm but not enough, I think, to explain the play encountered. The shaft is 30 years old.
Should I be concerned?
