BarryH
Ok, so one of the last jobs before I slap on the A/F is to clean and service and reseal the seacock for the bog.
The seacock in question is an old Simpson Lawrance item. Its very similar to a Blakes seacock, seperate flange outside the hull that bolts through.
Question is, it needs a good clean. There is a bit of barnacle growth in the inlet side, along with overpainted A/F and a bit of general crud. Could I soak it in vinegar to dissole the growth etc and clean the rest with a wire brush?
Once done I was looking to use some fine grinding paste to bed the 2 bits together and repack with grease. Do you think this is viable?
Looked at replacing it, but the Blakes jobby is 140 odd quid and theres not enough room behind the bog for the usual skinfitting/ball valve/ elbow pipe tail. Even then using decent fittings is as expensive as a Blakes fitting. Can't find any trace of SL stuff anymore, when did they go out of business?
Your thoughts would be greatly recieved, ta muchly.
