Cleaning Gas Cooker Burners
davidmh
30 Jan 2015
I have Plastimo Neptune gas cooker, the hob burners sometimes do not light all the burner outlets. I have tried scraping the cast iron burner top and poked out the burner holes and it is better but still not perfect. Since the Cast Iron head just lifts off I was thinking is there any solution you can dip the burner in which will dissolve the carbon build, some of it looks like rust.
David MH
IanCC
14 Oct 2019
David MH
Wire brush worked dor me. Get them really clean.
Metalicmike
8 Apr 2023
Tenerife
There is no shortcut, they are cast Iron and they do rust and the rust causes partial blockage. Modern burners are aluminium, maybe someone is producing aluminium replacements (would be good but I don't have a clue).
IanCC
14 Oct 2019
David MH
I think i used a drill bit the right size for the holes. Persist mine went from.awful to great.
plumbob
18 Oct 2009
Bucks
You can get gas burner files in a little set, but use a little bronze brush from a plumbers merchant and if you have power, vacuum on as you go.
davidmh
30 Jan 2015
Thanks for the replies, Stenmar has a point and this gap is created by the shape of the indents in tha casting. The idea of dipping it a mild acid to dissolve the rust is good, would Oxalic acid have the same affect, it seems to to remove rust stains from GRP.
David MH
