Cleaning Bilges
wizard
24 Jan 2003
Portland
What do people recommend to give the bilge a good clean especially in those places its hard to get at. I need something that doesn't leave a smell afterwards preferably.
It would have to be something that I could just pour in the bilge neat or diluted so I can leave it to swill around and then pump out later.
Ta in advance for all help
Washing machine pdr
back in the day when I had bilges that needed cleaning I used to use the detergent they use for cleaning overalls - available in all good supermarkets
no idea how eco it is - but it certainly worked a treat
and is cheap
you can use the rest up on your overalls afterwards
sparkling bilges - uberclean man
D
TFR Traffic film remover, spray on with the garden pump up thingy used for fence spraying or the small trigger spray. Wash of with hose and pump out.
I've used Natural Zest bilge cleaner smells nice.
But the best was a natural contamination of diesel bug on leaked diesel in the bilges. Spent last winter trying to find the source of bad egg smell. Found the water in my bilge keels very smelly with black streaked water but absolutely no oil or diesel that I could detect. All clean and odour free after a pump out and rinse.
I should have kept a sample for future cleaning.
What dont you understand about antifoul, that actually goes on the outsides
OK chick no need to boil! Since the thread is about cleaning the bilges of a boat and the bilges are the internal sump of a boat I'm not sure why you assumed that anyone would understand that you had suddenly changed the direction of the thread from the abbreviation a/f?
Anyway to answer your question they use Anti Fouling almost exclusively from Jotun or International. Far from being super powered it is usually far less effective than yacht varieties due to stringent controls on biocides placed on commercial shipping. It will likely be copper based and require near constant movement to be effective at all. Props are regularly cleaned by divers in port to keep them efficient.
However, the bilges are kept clean and do not require special paint or anti fouling .
