Cleaning Anchor chain
homerj
1 Dec 2003
Any good methods of cleaning anchor chain, mine has been lying in a puddle of grease and oil.
Trevor_swfyc
19 Jan 2002
Crouch
or use a solvent such as paraffin or diesel oil. Put the chain into a scrap 5 gallon container with 1 gallon of said solvent shake for 5 minutes discard solvent and remove clean chain. This will avoid removing any protective coating you may have on the chain also on the east coast not much sand available only mud! /forums/images/icons/frown.gif
All the best
Trevor
duncan
Home mid Kent - Boat @ Poole
Ah the wonders of mud!
I only suggested the chain thing because I have been out fishing on mixed gravel, shingle and sand banks and my stainless anchor has 'self cleaned' beautifull - best polishing job it's had.
@ how long is the chain ?
How long ...
What size ?
etc.
I have about 120ft 3/8 chain ..... I wouldn't like to try and put that in a container and swish it about .... even if I could lift it !!!
You could always lay out in a close single layer 'cheese' and then power wash it off ..... that's waht I did last time, but I didn't have it greased up etc.
<hr width=100% size=1>Nigel ...
Bilge Keelers get up further ! I came - cos they said was FREE Guinness !
/forums/images/icons/cool.gif
Chris_Rose
24 Jul 2003
Staffordshire
If your chain is blathered in oil etc Then do go for the barrel and parafin job. Even better fix two scrubbing brushes facing each other to pull the chain through, in the solvent. But please please wash the chain in hot soapy water and rinse well BEFORE IT GOES BACK IN THE SEA (think of the enviroment...
