BruceK
I discovered an oil leak through a duff gasket under the oil cooler. About 500ml of oil has made it's way into the engine bilge and mixed with the small amount of water the bigle pump doesn't lift. I temporarily disabled that bilge pump and pumped the mess out with a Pella vacuum pump. The bilge is now completely dry except for an oil water scum mix like a soft grease. Access to this under the engines is impractical as the engines are shoe horned in and where as I have line of sight I have no reach.
With the bilge pump disabled is there anything safe I can pour in that will dissolve the scum and oil after which I can use the Pella to evacuate and dispose safely?
