Chrome / Stainless effect 12v USB charger
bluetooth
30 Dec 2015
Poole
Anyone got any recommendations for one of these - looking to put in where marker on the photo to match rather than the standard black plastic one. For Fairline Targa 40.
Many thanks
Simon
No unless Ebay have them, however I fitted all mine to the blanks in the light switches ( assuming you have them - I had lots).
Cut a slot in the front and mounted it in Sika.
It was then powered by the same circuit that lights up the switches ( which you disconnect as you cant get to sleep!)
what brand are these outlets?
they are 4U (in eurospeak) see if they also do a 6U which would give you enough space to add 1 or 2 usb sockets from the same manufacturer.
I'm using VIMAR IDEA and that's how it works, your's look similar.
You'd have to cut a larger aperture on the bulkhead and make it symmetrical to the stereo on top. Would look good.
alternatively, have a look in case there are combo sockets with your UK 3pin together with usb in the same 2U space.
hope it makes sense!
cheers
V.
cheers
V.
Yeh - wanted it linked to 12v supply rather than shorepower/generator though. Playbus do a USB option so I could take out one of the 3-pin sockets.
Interesting wiring option. Did you do a different switch for the lights !?
A lot of these type of USB sockets can give a lot of interference on FM radio reception. I used them for a season and then binned them in favour of a standard 12v socket and a Belkin flush USB adapter. These and other good ones, are more expensive because they are suppressed. https://www.amazon.co.uk/AUKEY-Char...d=1547678605&sr=1-9&keywords=usb+car+chargers
OK thanks for warning. Changed my radio to DAB and aerial is about a metre away though generally use USB card or Bluetooth music from phone. Fingers crossed - not a big financial gamble !
Don’t follow.
The switches have. Constant 12v/ 24v supply for backlighting. I just used that. I specially do not want them backlit as they light the cabin.
Mine are mostly 3 switch plates with only 2 switches and a blanking plate
Ah sorry am with you now. Was thinking of lights with wall/ceiling mounted switches
Anyone any thoughts on taking power supply for USB charging socket from radio feed ?
Aware of comments above about radio interference.
In my case (see photo at start of thread) it looks very challenging to get a direct 12v supply to where I want it; but given its v close to the radio feed would make things easier.
Many thanks,
Simon
Many thanks,
Simon
It'll actually be easier to wire it correctly to the 12v distribution panel than the radio. You should already have a 12v socket breaker - just connect it to that. All very easy once you've removed the panel in the mid cabin.
Yeh Jimmy agree but its a tight squeeze for fingers when looking at area from mid cabin. Just wondered if the stereo link would be a problem or .... just do it properly! Im doing a separate USB socket for midcabin anyway which is easy to main dist panel.
S
