chocks, teak, stainless ?
adrianbarker
8 Nov 2001
Solent
Can anyone advise where I can obtain some teak, or similar, to make some new dinghy chocks ?
The teak will sit inside a stainless "U" that runs fore and aft on the bathing platform.
-and is this an easy job ? - Can I get a plan of the underwater section of the dinghy to ensure I get the correct shape on both ?
OR, is a stainless fabrication with "rubber" top bits any better ?
Any other advise appreciated.! - relevant to this though please !
So many questions, so little time !!
You didn't have that one the last time we saw you !
tcm
11 Jan 2002
Caribbean at the moment
wooden ones "age" whereas s/s will "get old, imho. Depends on the boat I suppose. dunno where to get teak where you are - a wood merchant will take an order - yellow pages?
For teak you need to be quite (very) handy woodworker. Use wire (like a coathanger) under the dinghy to transfer the hull form to workpiece. What's the dinghy made of - you made need something softer than teak for the thing to sit on, such as rubber, meaning that the form doesn't have to be correct to the millimetre.
Massively "rounding off" the chocks with a big "radius" on all corners/edges will make any slight imperfections dissappear and also make them less lethal to trip/fall over over/on.
Have a chat with Onward Trading in Southampton
or Solent Marine Chandlery in Gosport
either should be able to help.
oldsaltoz
4 Jul 2001
Australia, East coast.
G'Day Adrian,
To get the profile of your tender just cut a template from cardboard. Have you considered other materials? The white plastic board material (like bread boards are made of) seems to stand up very well, can't think of the trade name, no doubt someone will pick up the thread and remind us both.
Hope this helps.
Avaniceweekend Old Salt Oz....../forums/images/icons/cool.gif
Avocet
3 Jun 2001
Cumbria
Try KJ Howells for teak - I think they're in Poole.
If you want to use plastic, try UPVC but it's quite expensive for thick sheets and doesn't look half so nice as wood.
