I was told by my peers when i was younger "The more you put in the more you will get out! " This isn't true with boats the more you put in. The less you get out.
E:G My boat was leaking through the bow thruster so out she comes in Aug 02 to be repaired it has now turned into a major refit the QEII would be proud of.
Engines 14mm out of alighn new shaft couplings x2 , engine mounts perished, sweat glands replaced, prop shaft eaten away has to be resprayed with stainless steel, gbox cooling system furred up, Engine oil fxxxed, needs flushing & replaced new transducer for fish finder I could go on but not a fast typer. When the boat finally goes back in the water no doubt weather will change for the worse . Anyway i'm ready for the onslaught of winter . Anybody want to buy a P35
