chimney deck flange
firstascent2002
12 Jan 2004
Exeter
Hi Guys
Got a second hand solid fuel heater for the cabin. Did not come with flu or deck flange. Any thoughts on how I cen fit it in the deck? Got to be insulated and got to be very water tight and ideally any top section of chimney should be removable and the deck fitting plugged.
Help!
Re: Korrect Kuranda link...
I had a similar problem with a gas flue through a timber deckhouse, I got a flange/pipe made up in aluminium large enough to take the flue with a gap for insulation around it. It worked a treat and didn't set fire to the boat and the BSS chappie liked it as well (he complained about the previous owner's original attempt). The outer sleeve was taken up to the underside of the terminal of the flue to prevent water ingress.
