peter2407
Tragic circumstance. Appaling loss of lives. What can we learn. Circumstance - large ingress of water. Look for cause/source, but what to do in the meantime? My boat has a raw water filter that services a sail drive leg so my main seacock is on the SD Leg. White hose leads from raw water filter to SD inlet. As per MAIB Report, if i start the engine to use the cooling pump as effectively a bilge pump, where does one start? Cut the white pipe at the raw water filter end, and point that at the wet stuff, or the SD end, or what?
