superheat6k
Decided to check the valve tappet clearances today, the found out my manual was a bit vague on the subject, and the workshop manual I have for the TMD40 on my last boat has differing settings and valve sequence.
So having established which valve was which actually setting this valves was straightforward.
So I thought I would write it down as an aide memoire for the next time I tackle this task.
Might be of use to some one, if so you can find the details here. The valve order is specific to the TAMD60C which has differing clearance settings on the inlet and exhaust, but the firing order should be the same for any 6 cylinder engine. If your engine has the same clearance for both valves then the specific sequence is not critical.
https://www.dropbox.com/sh/10uvecr9c9yki0o/AAAXSzW3p-hYQbxCVjOh170na
