Checking NMAE feed
Vara
20 Feb 2004
Canterbury/Dover
Playing with an old plotter, does not seem to be transmitting NMAE data.
Is there any way of detecting signal using a multimeter or similar?
aparently nema data can be detected with a led between the signal and ground wires, (obviously the nema out pair), seen as flashing.
NMEA :)
The ideal would be an oscilloscope, failing that I would try connecting to a PC serial port. Some other NMEA kit (eg my CP180i plotter) has a diagnostic mode in which it displays everything it reads on the input.
NMEA :)
Had a quick look in the shed no oscilloscope, bit short of serial ports on the Ipad, cant see a diagnostic mode.
I'll just put it on ebay as a spares job as everything else seems to work OK, I don't really need 3 plotters.
Thanks all.
