chumblefish
Hi, I've recently installed a 100 watt panel with the typical cheap solar controller found on most eBay listings of solar kits.
The symbol of the solar panel on the lcd display has a flashing arrow pointing at the battery (which is the centre symbol). If the arrow is flashing, as it is, does that indicate its not charging the battery? If so, what might be the problem? Also the second arrow shows solid, unblinking to the light bulb symbol (the load) even when nothing is plugged in to the USB sockets on the controller or any cigarette lighter type sockets in the boat. Presumably the arrow means some charge is going out somewhere. Any suggestions of what I could do to identify where the leak is? I have a multi meter but don't know where to check in this case.
