Philiz
My recently acquired boat is has 2 chartplotters, a Foruno and a Lowrance. The Foruno unit is getting on a bit and although good quality it doesn't have the detailed display of the modern units. The Lowrance is quite good but the display is quite small.
The plan is to re-site the Lowrance unit up on the flybridge as there are no electronics at all up there at the moment, and to replace the Foruno unit which is at present flush mounted in the fascia.
I would like to fit the new plotter in the aperture left by the Foruno, with a bit of trimming if necessary, but the fascia restricts the dimensions of the plotter to 10 x 6 inches (landscape format) give or take 1/4 inch.
I've been looking at the larger Lowrance units but have been put off by stories of poor reliabilty so my choice seems to be restricted to Raymarine or Garmin. I will be looking to get a Plotter and Radar package, or to add radar later.
Any advice, pros and cons of each system would be appreciated, together with any other options I might look at. New Foruno and Simrad units look too expensive!
Any views on multi display units compared with seperate plotter and radar display set ups?
Thanks in advance.
Thanks in advance.
